It shows 4 wires on the alternator, mine has only one, the other 3 have been capped and stowed.
I have no ignition light, I checked the local light wires, there is 12 volts from the fuse but no ground thru the wire to the ignition warning light unit (3 AW)
With the single wire alternator how does the ground (marked earth) activate if the wires from the alternator are capped.
If anybody could help on this I would be eternally grateful, don’t get you hopes up on the eternal thing, I am 71.and can’t remember what I did yesterday.
Thanks,
Terry
