Trailing Arm Dimensions ?
showone
#1 Trailing Arm Dimensions ?
Post by showone » Sat Mar 28, 2020 10:11 pm
The trailing arm or radius arm on a series 3 xke , is it the same length as the series 2 xj , center hole to center hole , only a different shape? Would like to use the xj trailing arm on the series 3 xke to gain more clearance at the back of the rear tire for wider tires. Has anyone done this?
