A welding warning!
Rich70
#1 A welding warning!
Post by Rich70 » Sat May 23, 2020 10:55 am
I thought I would quickly share what I found whilst stripping the rear of the car today.
The PO had welded (poorly) a patch on the rear RH wing but the welding splatter has almost burnt through the fuel tank feed line to the pump! The blister was so thin I punctured it with a pin!
Always make sure the inside surface is clear and safe before welding on the other side!
Richard. UK RHD 1970 S2 2+2 Auto.
H7OB
#2 Re: A welding warning!
Post by H7OB » Sat May 23, 2020 11:51 am
Wow, that is scary! Good that you found it.
'68 Series 1.25 2+2
Jeremy
#3 Re: A welding warning!
Post by Jeremy » Sat May 23, 2020 1:42 pm
Jeepers. I wonder if the car had fuel in it when he was doing the welding.... :wow:
Jeremy
1967 S1 4.2 FHC
MichaelDesna
#4 Re: A welding warning!
Post by MichaelDesna » Sun Jul 26, 2020 8:08 pm
Wow, Rich, that's scary. It makes you wonder sometimes what people are smoking when they work on cars. Well, let's hope they're not smoking at all ! :wow:
