Just a dumb question: should the engine number and the cyl head number match? I had an interested buyer look at my 68 2+2 and he said my cyl number was different so not original to the car.
thanks for the help.
matching numbers?
#2 Re: matching numbers?
They should match. where present, although cylinder heads stopped being painted and numbered in the later sixties.
#3 Re: matching numbers?
This thread gives detailes from Jaguar hetitage trust of from what engine numbers the head stamo was ommited http://forum.etypeuk.com/viewtopic.php? ... cf#p110905
#4 Re: matching numbers?
I thought that the block number is the important match ...cylinder heads could be easily replaced and therefore wouldn’t have an engine number stamped
#5 Re: matching numbers?
thanks, that cleared things up nicely.
Alfred
Alfred
1968 2+2
#6 Re: matching numbers?
Ideally, Block, Cylinder Head, Crankshaft and Flywheel should all have the same numbers on them.... Unsurprisingly, the latter two are not often available . If you ever have your engine reconditioned get these photographed when it is stripped down - a really nice thing to add to the provenance of the car.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#7 Re: matching numbers?
Yes...mine has everything but the flywheel stamped! I was rather delighted to see the engine number on the crank !
#8 Re: matching numbers?
I saw a post on FB recently that showed a gearbox mount plate with the body number stamped in it....Steve
