Wheel clamp??
Bernie2015
#1 Wheel clamp??
Post by Bernie2015 » Sat Feb 27, 2021 1:53 pm
Does anyone know if this is for an E type - just found it in the garage and have owned all three series at one time or another. It looks a bit long to me.
Bernie 1966 S1 OTS
Robbiee
#2 Re: Wheel clamp??
Post by Robbiee » Sat Feb 27, 2021 2:47 pm
The design is just like my S1 etype one but, like you say, it looks a bit long in the shank!
Maybe it would work if the wheel was upside down ??
Robbie
#3 Re: Wheel clamp??
Post by Gfhug » Sat Feb 27, 2021 6:06 pm
Is the S3 version longer :shrug:
vee12eman
Kiribati
#4 Re: Wheel clamp??
Post by vee12eman » Sat Feb 27, 2021 8:57 pm
It’s for an S3 I believe. They are longer. I can measure mine to confirm if you want.
Series III FHC
AussieEtype
#5 Re: Wheel clamp??
Post by AussieEtype » Sun Feb 28, 2021 4:36 am
The cross piece is not rectangular on a Series 3 - it is a pressed circular fitting that fits into the centre of the wheel to hold it in place. The rest looks correct.
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
vee12eman
Kiribati
#6 Re: Wheel clamp??
Post by vee12eman » Sun Feb 28, 2021 6:08 am
It’s rectangular on my very early car. (97th RHD coupe). I am pretty sure it’s original, but you never know...
Simon.
Series III FHC
Bernie2015
#7 Re: Wheel clamp??
Post by Bernie2015 » Sun Feb 28, 2021 10:30 am
If you could measure it i would be grateful thanks and solve the mystery
Bernie 1966 S1 OTS
Bob.
#8 Re: Wheel clamp??
Post by Bob. » Tue Mar 02, 2021 7:07 pm
Hi Bernie
AFAIK S1/2 spare wheels were always supplied stored face down using a short shaft handle and rectangular clamp. With a redesigned boot floor to accommodate a larger fuel tank, S3s had the spare mounted face up so the clamp needed a longer shaft.
Two versions are listed, BD36809 for the standard steel wheel and BD36808 for wire wheels, where the clamping face is further away from the floor - at a guess a couple of inches. Initially it appears that the S1/S2 rectangular plate was used, but is present on cars produced up until June 1971 (over 1500 cars produced by then) when the round clamp plate seems to have been fully adopted.
My car was originally supplied with wire wheels and the clamp shaft is 8ins from the underside of the round plate to the end of the thread, but I am guessing that Simon's would be significantly shorter as I think his car came originally with steel wheels.
Sorry for quality of picture.
Bob
Bob
'71 S3
AussieEtype
#9 Re: Wheel clamp??
Post by AussieEtype » Wed Mar 03, 2021 3:58 am
Bob - your post would tie in with my both Simon's and my responses. His being a very early S3 has the rectangular plate and mine being a Jul/Aug 71 build S3 has the round plate. Mine has disk wheels and the clamp while looking like yours in the pic is much shorter - is packed away somewhere and cannot measure it at the moment.
Garry
Bernie2015
#10 Re: Wheel clamp??
Post by Bernie2015 » Wed Mar 03, 2021 7:54 am
Thanks very much mystery solved!!
Bernie 1966 S1 OTS
Bob.
#11 Re: Wheel clamp??
Post by Bob. » Wed Mar 03, 2021 9:07 am
Hi Bernie,
Interested to know if yours is the shorter S3 version and if so what length it is.
Bob
Bob
'71 S3
Bernie2015
#12 Re: Wheel clamp??
Post by Bernie2015 » Wed Mar 03, 2021 9:58 am
Length available below the clamp is 165mm
Bernie 1966 S1 OTS
Bob.
#13 Re: Wheel clamp??
Post by Bob. » Wed Mar 03, 2021 1:14 pm
So 1.5ins shorter for a steel wheel than for a wire, that makes sense.
Bob
'71 S3
Bernie2015
#14 Re: Wheel clamp??
Post by Bernie2015 » Wed Mar 03, 2021 1:38 pm
You learn something new every day!!
Bernie 1966 S1 OTS
Robbiee
#15 Re: Wheel clamp??
Post by Robbiee » Wed Mar 03, 2021 1:51 pm
Here’s my(restored now) S1 ‘62 3.8clamp for comparison
Robbie
