Low Oil Pressure solved
Dave Dawson
Topic author - Posts: 6
#1 Low Oil Pressure solved
David Dawson E-type 68 S2 2+2 o/d E-Type 68 S2 OTS Frogeyed Sprite
Triumph Tr5 pi Tr3a
Triumph Tr5 pi Tr3a
#2 Re: Low Oil Pressure solved
Are you owning up to that Dave ?
Barrie
Barrie
#3 Re: Low Oil Pressure solved
Easy to do and as a further challenge some gasket kits come with multiple different gaskets.
Dave Dawson
#4 Re: Low Oil Pressure solved
Triumph Tr5 pi Tr3a
Triumph Tr5 pi Tr3a
#5 Re: Low Oil Pressure solved
We all make mistakes! I had low oil pressure on a 3.8 about a month after a rebuild - I stripped out the filter block and found a wire brush bristle on the relief valve seat.
Barrie
Barrie
#6 Re: Low Oil Pressure solved
sorry for the old thread, Is this picture of the gasket incorrectly installed?Dave Dawson wrote: ↑Mon Jun 21, 2021 1:05 pmHI Forumites My E-type has had low oil pressure at Hot idle 10 psi since it was rebuilt by my self in 2014 . while Checking over my E-type over,[just before the 60th meet at Shelsey Walsh] i noticed an oil leak from the PRV on the oil filter head, on removing the complete head I found the gasket was fitted back to front, so oil had been leaking past the prv on the LHS, on replacing the gaskets correctly the hot idle pressure increased to 25 PSI [Smiths electrical gauge] .IMG_0459.jpg
S1 OTS 4.2 1966
I really go to put this thing back together
#7 Re: Low Oil Pressure solved
That's what the first post says....Steve
#8 Re: Low Oil Pressure solved
I think so.
#9 Re: Low Oil Pressure solved
Yep, definitely reversed.
This design obviously pre-dates the adoption of poka-yoke techniques, etc.
No wonder the Japanese companies kicked our backsides with quality and reliability.
