Oil pressure
Joes66
#1 Oil pressure
Post by Joes66 » Fri Aug 13, 2021 2:03 pm
Finally putting some longer journeys on my E and quick question on oil pressure
I've been using the car daily for a couple of weeks and went down to hailing Island the other day
Probably 60 odd miles there
Kind of went easy on the way down and no problems other than a blowing exhaust
On way back pushed it fairly hard for the last 20 miles or so
Question is
Start up cold with used oil rather than new oil I get about 50 psi
With about 40 psi idle
Once hot I get about 20-30 psi idle and 40 psi hot on a run holding steady
But after that hard run I came off the motorway to a stop and the oil pressure dropped to about 10 psi or slightly less at idle
It came back up to 40 psi once I got going again
I parked the car up for a bit and oil pressure after starting went back to about 20 psi hot
Does this seem odd or is it normal for an older engine
No noises other than a slight tapping from the top somewhere which it's always had
I have the standard guage and sender
4.2 engine
Joe
1969 series 2 2+2
#2 Re: Oil pressure
Post by mgcjag » Fri Aug 13, 2021 2:29 pm
Hi Joe....standard electrical guage and sender will just give you an indication of pressure...they are often far from acurate.....the only way to tell exact oressure is with a wet guage.....Steve
tinworm
#3 Re: Oil pressure
Post by tinworm » Fri Aug 13, 2021 3:23 pm
Yep Steves right - buy a nice glycerine filled gauge and test your actual pressure. The electric gauge is just a voltmeter really - you may have a bad connection.
Barrie
#4 Re: Oil pressure
Post by christopher storey » Fri Aug 13, 2021 4:17 pm
I doubt whether in this particular case it is a result of gauge inaccuracy , as on my mark IX with its Bourdon tube gauge the results are almost identical to yours - when very hot at idle I get 12 lbs/sq.in but it goes straight back up to 40 once off idle, and I have been told not to worry
Joes66
#5 Re: Oil pressure
Post by Joes66 » Fri Aug 13, 2021 7:59 pm
OK
Thought as much
Thx for replies
I will try a mechanical guage
Do they do a replacement one?
That looks the same?
Joe
1969 series 2 2+2
#6 Re: Oil pressure
Post by abowie » Fri Aug 13, 2021 8:40 pm
Those numbers are fine.
