Yes it is kind of a "prototype", the pump body is hard plastic/nylon just like the fuel lines.
The pump is firmly stuck to the rubber mount and I did not want to drill the rear bulkhead/panel until I am 100% confident on the setup. I may move the pump as far to the left (from the rear) as possible before bolting it down.
3.8 in-tank fuel pump.
#61 Re: 3.8 in-tank fuel pump.
61 OTS Black on Red, 62 FHC nuts & bolts resto on the way to OSG & Matador red.
