There is certainly something odd with this Diff !
The output shafts are definitely of the later type as the early differentials had a large nut holding the drive flanges on. I still can’t determine if this is a Type 2 or a Type 3 differential and also the “offside” outer bearing housing does not have the separate caliper mounting bracket - as seen on the “nearside” side. On the later differentials they had that caliper mounting brackets cast in the bearing housing.
I must admit I didn’t realise the number “68” identified the year the differential was built, but that makes sense. I have some diffs here with various “year” numbers stamped on which are all earlier dates than the cars registration dates they came from that I do know. Sometimes these dates are several years previously, but it still makes sense that that is the year of the differential build. I would be grateful if someone could positively confirm this “year” stamping as it will greatly help identify any differential.
As regards confirming the ratio, the only true way is to remove the cover as on the Crownwheel there are two numbers which give the number of Crownwheel teeth and the corresponding number of the matched Pinion teeth. Such numbers are 46/13 which gives a ratio of 3.54 : 1. The BP-L tag signifies a Powr-Lok Limited Slip differential which will become apparent as soon as you have the cover off as this is a large unit containing the various clutch plates. The easiest way is just to turn the outputs shafts which will turn in the same direction on a Limited slip differential as the shafts are normally locked together- as opposed to an “open” differential where one shaft will turn in the opposite direction to the other.
The other important part is not so much the differential itself - as many Jaguar differentials can be relatively easily still obtained - it is the inner fulcrum mounting brackets, as mentioned in post #2 these are unique to the E Type and very, very difficult - or very, very expensive to buy the re manufactured items now. I did contribute to post on these brackets previously:-
viewtopic.php?f=3&t=10004&start=20
Finally, the colour choice is unusual- almost military in colour.
Just my thoughts.
