coil, ballast resistor??? 67 with points,
#1 coil, ballast resistor??? 67 with points,
Hi, I have two coils that came with basket case car, no markings on them, how do I know if I need a ballast resistor on one of them?? Thanks Mike.
#2 Re: coil, ballast resistor??? 67 with points,
In the interests of reliability of your completed car I would think that the cost of a new Lucas coil for it would be a wise investment. Price in the UK would be less than £20.
#3 Re: coil, ballast resistor??? 67 with points,
The S1 cars did not use ballast coils, the S2 did.
S1 OTS OSB; S1 FHC ODB
#4 Re: coil, ballast resistor??? 67 with points,
Also if keeping a points system invest in new rotor arm, points and condenser from the Distributor Doctor, or new old stock items, not brand new ones even if they are in lucas packs.Jack the lad wrote: ↑Sun Feb 05, 2023 4:10 pmIn the interests of reliability of your completed car I would think that the cost of a new Lucas coil for it would be a wise investment. Price in the UK would be less than £20.
Andy
1967 Series 1 4.2 OTS
Leicester, UK
Leicester, UK
#5 Re: coil, ballast resistor??? 67 with points,
Hi Mike.
Typically, ballast resistor coils are just over 1 ohm,
non-ballast coils are around 3 ohms.
That’s the one you should use.
Regards.
Regards.
John Gadbois
'66 E-Type 2+2, ‘64 3.4 MK2
Montreal, Quebec, Canada
