My ‘68 2+2 restoration project that has been dry stored for over 75% of its life is about to lose its currents home so I’ve got to relocate it.. hopefully to home if I can make space. I’ve had the car for 5 years now and have cranked it over by hand regularly without issue although I’ve never tried to start it…… but I’m itching to try! The car hasnt been started for about 20 years so what could possibly go wrong. All I’m looking to achieve here is to start it up drive it 100ft onto a trailer and then turn it off. Ha!
So assuming the clutch isn’t stuck and the carbs aren’t blocked and I can get clean fuel into it with half a dozen sparks all at the same time is there anything else I should consider or should I just secure the help of half a dozen blokes to push it on to the trailer?
Start it or tow it?
#2 Re: Start it or tow it?
Hi Phil....for the sake of just getting it onto a trailer i dont think its worth the effort...fresh fuel..battery...get it started...clutch?..then brakes...wiil it stop as you drive on.....2 can push quite easily......Just my opinion...but you could pull the spark plugs...slip it in gear and "drive" it on the starter motor.......Steve
#3 Re: Start it or tow it?
Or just winch it on.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#4 Re: Start it or tow it?
It'll be quicker to push it onto the trailer. One way to go "uphill" is to take a couple of old square wooden fenceposts and lever it it along inch by inch so you can't ever roll back downhill. The bigger the fencepost, the more leverage you have.
Plenty. Even with a relatively fresh car, it's generally not a great idea to start it and then not get it up to temperature properly. There are so many additional factors on top of just running the engine - like rusted calipers, perished rubber - the list might be quite long.
