Small Petrol Leak
SimonBrown
#1 Small Petrol Leak
Post by SimonBrown » Sun Dec 24, 2023 5:39 pm
Had to leave the ignition on today whilst repairing the reversing lights (about 5 mins) and noticed the fuel pump does not quite stop ticking, perhaps once every 20 secs or so, followed by a smell of petrol.
There is a leak from all three carbs.
On removing the air cleaner there is a pool of petrol coming from the main jet area/ bottom of piston and leaking out under each trumpet. Once the engine is running, then no leaks.
I have checked all floats and valves and they appear to be shutting off correctly.
Anyone else experienced this or should I just not leave the ignition on without running the engine?
Thank you
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
#2 Re: Small Petrol Leak
Post by mgcjag » Sun Dec 24, 2023 7:01 pm
Hi Simon the fuel in the float bowl isnt shutting the pump off.... either a sticky needle valve or possibly a leaky float thats sinking a bit....or float gap setting isnt quite correct... Steve
neal herridge
#3 Re: Small Petrol Leak
Post by neal herridge » Mon Jan 01, 2024 6:02 pm
Hi Simon.
There is nothing wrong with leaving the ignition on, just remove the white wire at the coil to stop it over heating. Its a good way of checking you are not getting flooding.
What fuel pump do you have if its been changed from standard you may have to higher fuel pressure.
Have you got the notched fiber washers on the bottom of the banjos , also you can lower the fork height from the 11 mm to a max. of about 12 mm . Also check the forks & the needles are not jaming when they are on full drop .There is a tag on the back of the fork to stop this.
Neal.
SimonBrown
#4 Re: Small Petrol Leak
Post by SimonBrown » Wed Jan 03, 2024 5:54 pm
Hi Neal,
Thanks for info, I have lowered the float heights by a couple of mm and this appears to have stopped it flooding
Simon Brown
1975 Honda 400 Four
