I am just rebuilding a 66' brake servo.
The servo push rod is fixed in the primary piston by a pin, and there is a small coil spring in the piston.
The manual says that " the spring should be loaded between the heel of the piston and the pin".
I am not sure if I understand correctly what the heel is and I have to admit that I dont understand the function of the spring at the moment (should it dampen the servo kick-in?).
Is this the correct position of the spring?
Thank you
