Hi, I've been reading old posts re brake pads. Mintex 1144 seem favourite over greenstuff. what are the preferred pads when Zeus 4 piston callipers are fitted to the front ?
Zeus calipers brake pads Mintex ?
Stevejaguar
Topic author - Posts: 177
#2 Re: Zeus calipers brake pads Mintex ?
Hi Steve, I can only tell you my experience. I use green stuff pads with fosseway 4 piston brakes with vented discs, the car can stop on a sixpence absolutely excellent, for what’s its worth I put vented discs on the rear too, a simple conversion with the irs out, thought it would help out with all the heat generated down in that area, can’t speak highly enough of that conversion.
S1 2+2 manual. (Sold)
Stevejaguar
#3 Re: Zeus calipers brake pads Mintex ?
Hi, thanks for your thoughts. I will go down that route when I get around to the brake rebuild.
