Odometer Stuck
SimonBrown
#1 Odometer Stuck
Post by SimonBrown » Fri Nov 01, 2024 8:49 pm
As my E turned 90000 miles, the odometer has stuck at 89999 and a bit. The trip meter has jammed also, however the speedo still works fine.
Would anyone know if this is an easy diy fix or is it necessary to send it away for a refurb to one of the Speedo specialists?
Thank you
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
#2 Re: Odometer Stuck
Post by bitsobrits » Fri Nov 01, 2024 9:37 pm
I've had a couple of times when this occurred with Smiths speedometers, though not E type. In both cases, a plastic geared wheel had stripped a few teeth (possibly due to my lack of lubricating the drive cable-but who really does that?). In one case I was able to borrow the part from a cosmetically inferior spare I had from another car. Not an easy task, as I recall, but working in the end. In the other case, it went to a specialist.
The moral, I suppose, is that if you can identify the cause and can obtain spare bits, then it's within the realm of DIY. Otherwise best to spend the coin for expert service.
Etype63ca
#3 Re: Odometer Stuck
Post by Etype63ca » Sun Nov 03, 2024 6:50 pm
I just had my stuck Speedo repaired by Speedograph Richfield and was very happy with the service and the price
