Long story short... My water pump failed while on tour in Spain. What is the recommended gasket sealer these days? Is Hylomar Blue still the recommended solution or is there something better?
Thanks in advance.
dave
Water pump gasket sealer?
#1 Water pump gasket sealer?
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
#2 Re: Water pump gasket sealer?
Dave, if Hylomar the aerograde PL32 is the better product, Wellseal also gets good reviews. The latter is what I used when changing the water pump, though have always used the PL32 before on the car. Hope that helps
flatfloor 3.8
#3 Re: Water pump gasket sealer?
Wellseal every time, far superior product. Clean metal surfaces with brake cleaner then apply a thin coat to all 4 surfaces and leave for 15-30 mins before assembly.
Last edited by flatfloor 3.8 on Fri May 23, 2025 3:43 pm, edited 2 times in total.
Bill S1 3.8 OTS.
#4 Re: Water pump gasket sealer?
+1 for Wellseal.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#5 Re: Water pump gasket sealer?
Thank you guys, Wellseal appears to be the way to go.
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
