I have an S3 which appears to have a differential which is non-standard for S3 cars. The manual states there should be ball bearings on the two output shafts, but I have taper rollers with what looks like a crushable spacer separator. The bearings are in good condition, I am merely replacing the output shaft seals.
Here’s one of the bearings, the tie-wrap is merely to ensure the order is not mixed up on reassembly. The seal is already removed at this stage.
The differential serial number:
It looks like:
H 76
P
2885
I want to re-use the bearings. Do I need a new deformable/crushable spacer, or can I re-use this one, by tightening the nut to the same slot of the tab washer? The nut was not very tight, relatively easy to undo rather than super tight as I half expected.
If I require a new spacer, what is the part number and where can I get one? It’s not listed in the parts manual and I haven’t been able to identify one in the other parts manuals for other models, which list spacers and shims.
Can anyone help, I’m in Melbourne, Victoria, Australia, if there’s anyone I can talk to/visit, but I don’t really want to farm out the whole job, which rather defeats the object of my ownership, which includes doing the maintenance myself wherever possible.
This is the S3 manual image, clearly a double row ball bearing with a different casting to hold the seal and bearing/s
