Torsion bar removal
Freddie116
#21 Re: Torsion bar removal
Post by Freddie116 » Mon Nov 17, 2025 8:59 pm
It works! Now to slide the TB off….
angelw
#22 Re: Torsion bar removal
Post by angelw » Mon Nov 17, 2025 9:42 pm
But of course! :bigrin: And as you have probably discovered, you don't have to disengage the wishbone from the Torsion Bar, if your only endeavor is to replace the bushes. However, when replacing bushes, I like, at the least, to clean the wishbone thoroughly, but usually to do a full refurbishment of the wishbone components.
Freddie116
#23 Re: Torsion bar removal
Post by Freddie116 » Mon Nov 17, 2025 10:05 pm
Yep - I love this forum! I’m afraid I’m not doing a full on job. I will clean everything up to a degree with wire wheel etc - 60 years of brake dust mixed with oil on an unrestored 1965 car (we’ve had it a long time).
#24 Re: Torsion bar removal
Post by mgcjag » Tue Nov 18, 2025 9:41 am
Hi Freddie....I think at this stage it would be a bit short sighted not to remove the torsion bar and rear adjuster...you've done the hard work...it would mean you could easily dress the splines and sort out why the bolts wouldnt come out.....it would make future ride height adjustment much simpler.....Steve
