Engine breather drain
16024d
#1 Engine breather drain
Post by 16024d » Sun Dec 14, 2025 11:27 am
Does the engine breather system have a drain hole? If so has any one a picture of the location. 3.8 1962 Thanks
#2 Re: Engine breather drain
Post by Gfhug » Sun Dec 14, 2025 12:07 pm
Hello, do you have a name? Please add it, it’s more polite to answer that way.
The pipe from the engine to the carb air box has a small hole on the under side, though it can easily get blocked. If you clean the pipe and run your finger nail along the under side you’ll find it.
Also, searching for “breather” can give you lots of answers, too.
16024d
#3 Re: Engine breather drain
Post by 16024d » Sun Dec 14, 2025 12:47 pm
Hi Geoff, thanks for the info. I bought a new breather pipe but didn't notice the hole. I will take it off and try to find it. I have searched breather but mostly about the routing of the pipe.
