Original Lucas lamps E type S1 (UK spec)
rdaustin
#1 Original Lucas lamps E type S1 (UK spec)
Post by rdaustin » Fri Jan 16, 2026 9:56 am
Hi there. Looks like our E type has 1 original Lucas sealed beam lamp and 1 sealed beam aftermarket replacement (think the car had a bump many many years ago). I see that some Lucas lamps had the pilot bulb/light and some didn't. How do I know whether mine does or not? (We're contempalting replacing the aftermarket one with a Lucas original). Car is 1965 S1 4.2 OTS RHD (it's a very early 4.2, so has some carry over 3.8 parts on it). Thanks.
#2 Re: Original Lucas lamps E type S1 (UK spec)
Post by mgcjag » Sat Jan 17, 2026 8:24 am
No side light bulb in headlamp as far as I'm aware on E types...Jaguar parts catalogue should be your go to place for parts for your chassis number...Steve
#3 Re: Original Lucas lamps E type S1 (UK spec)
Post by Heuer » Sat Jan 17, 2026 12:38 pm
Everything you need to know about headlamps can be found here: viewtopic.php?p=35109#p35109
rdaustin
#4 Re: Original Lucas lamps E type S1 (UK spec)
Post by rdaustin » Sun Jan 18, 2026 10:28 am
Thanks Steve & David - much appreciated
