Oil Pressure sender 3,8
#1 Oil Pressure sender 3,8
Hi has anyone tried the oil pressure sender from Classic Jaguar. They claim it is made to OE spec £144 but is it just a generic one selling for more money.
Thanks Adam
3
Thanks Adam
3
#2 Re: Oil Pressure sender 3,8
Don't waste your money, install a mechanical oil pressure gauge for much better accuracy. Details in the 'Upgrades' part of the Forum.
flatfloor 3.8
#3 Re: Oil Pressure sender 3,8
As above, fit a wet gauge and be done with it. All the senders are unreliable.
Bill S1 3.8 OTS.
#4 Re: Oil Pressure sender 3,8
Thanks I will look into that,
Adam
Adam
#5 Re: Oil Pressure sender 3,8
It's not original. Position of the terminal is the giveaway Original had the terminal in the centre, this one has it on the side. The difference is dictated by the internals. The original with centre terminal was a Smiths bi-metalic type that was passably accurate when paired with our bi-metallic gauges; NLA. The senders with the side terminals are resistive type, substituted by Caerbont, that do not work well with original Smiths gauges, not accurate or reliable.
#6 Re: Oil Pressure sender 3,8
I have now ordered wet gauge, with nylon pipe as recommended in thread thanks for your help.
Thanks Adam
Thanks Adam
#7 Re: Oil Pressure sender 3,8
Hi I lowered gauge panel, I found voltage regulator is connected to oil pressure gauge is this correct for a 63 car
Adam
Adam
#8 Re: Oil Pressure sender 3,8
Adam, have you looked at the wiring diagram? You’ll see the voltage regulator is connected to the oil pressure gauge. Maybe you’re misinterpreting what you are seeing. Check which terminals that wire is going to and maybe it is on the correct one
#9 Re: Oil Pressure sender 3,8
Sorry I read a post that said its not connected to voltage regulator
Adam
Adam
#10 Re: Oil Pressure sender 3,8
Post I read said it is only used for temp and fuel gauge ,
Adam
Adam
#11 Re: Oil Pressure sender 3,8
To be clear, the oil pressure gauge, as original, operates from battery voltage. It receives this battery voltage off the INPUT terminal on the dash voltage regulator, not from the regulated voltage of the dash voltage regulator.
Tom
Tom
#12 Re: Oil Pressure sender 3,8
That is correct.
#13 Re: Oil Pressure sender 3,8
Thank you for helping me out.I should have looked at the manual
Adam
Adam
#14 Re: Oil Pressure sender 3,8
If you are fitting as you mention above, a mechanical oil pressure gauge, then the only electrical connection would be for an illumination bulb.
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
#15 Re: Oil Pressure sender 3,8
Thanks again for every ones input such a great place to get advice.
Adam
Adam
#16 Re: Oil Pressure sender 3,8
Hi I have fitted a wet gauge getting great oil pressure reading so thanks again for the advice.
Adam
Adam
