Rev counter generator
Stevemorris
#1 Rev counter generator
Post by Stevemorris » Fri Jun 05, 2026 6:21 am
My rev counter isn’t working, even if I tap it!
I’ve checked across the terminals for a Voltage, zero…
I did hear or read somewhere that you can get these re magnetised, does anyone know where or indeed if it’s possible?
Thanks, Steve.
1965 Jaguar ‘E’ Type FHC
tim wood
#2 Re: Rev counter generator
Post by tim wood » Fri Jun 05, 2026 7:59 am
Is it definitely rotating? Not unknown for the drive dog to become distanced from the camshaft
Tim
#3 Re: Rev counter generator
Post by mgcjag » Fri Jun 05, 2026 8:07 am
Or to snap off
Stevemorris
#4 Re: Rev counter generator
Post by Stevemorris » Fri Jun 05, 2026 8:09 am
Thanks chaps,
I have to remove the rearmost cam cap to renew a stud, so I'll check when I do this, and let you know! The drive is still intact Steve I took it off to renew the seal, it is spinning as well, plus I could feel the coupling in the cam and it felt OK?
Steve.
Simonpfhc
#5 Re: Rev counter generator
Post by Simonpfhc » Fri Jun 05, 2026 2:03 pm
The generator creates an AC voltage that increases by 1v every 1000rpm. You could try measuring the output first.
62 3.8 FHC
91 Porsche 928GT
Stevemorris
#6 Re: Rev counter generator
Post by Stevemorris » Fri Jun 05, 2026 4:05 pm
Hi Simon, yes already done that and at 1,2,3,4000rpm zero Volts!
Thanks,
Steve.
