ALTERNATOR ANYONE?
Stevemorris
#1 ALTERNATOR ANYONE?
Post by Stevemorris » Thu Jun 04, 2026 2:58 pm
OK, I think I have finally found the bottom of the pit...
The initial issue was with the Ignition/Oil pressure warning light. It comes on but only for a split second, then goes off even before I've hit the starter button! The car is showing charging on the ammeter, and with a multimeter across the battery it's definitely charging.
So, what's the problem? I hear you ask...
Well,,,,,
My car is a 65 FHC and as such the ignition warning light should in fact be an oil pressure light, but there is no switch in the block, and behind the rev counter is a 3AW warning light canister, with some home made wiring to it. The car has, at some point, been converted to the 3AW warning light system, but it doesn't work.....
So, I found the extra wire for the oil switch (someone had put both, sender and switch wire, on the 2 terminals on the oil pressure sender!) This wasn't an issue as I traced the other end of the wire to behind the speedometer, which had been cut off to accommodate the wire for the 3AW canister.
Attached is an image or two of the offending objects. The 3AW canister looks as though its wired correctly, an earth wire (which is now attached to a proper ground... :doh: ), a fused supply (white) and an ALT wire (blue) which ends up at the alternator of course. Now I do get how this works, the warning light bulb is grounded by the alternator when stationary, and as soon as it starts spinning the ground is broken, and the light goes out, simple.
But as you can see from the photo, the blue ALT wire is actually piggybacked onto a red wire that goes to a separate terminal stand alone on the back of the alternator?
My if I disconnect that wire the car doesn't charge.....
My thoughts are that for whatever reason someone has switched this to a 3AW W/L set up, and either fitted a different alternator or wired it incorrectly?
HELP PLEASE!!!! :bigrin: :bigrin: :bigrin:
Steve.
1965 Jaguar ‘E’ Type FHC
#2 Re: ALTERNATOR ANYONE?
Post by Gfhug » Thu Jun 04, 2026 3:50 pm
Steve, would fitting a self regulating alternator be an easier fix
viewtopic.php?f=5&t=18033&p=146682&hili ... or#p146682
Various amp alternators can be found
MSM
#3 Re: ALTERNATOR ANYONE?
Post by MSM » Thu Jun 04, 2026 4:06 pm
Don’t understand the relevance of showing the water temperature sensor in photo 4?
Are you calling this the oil pressure sender?
Mike
1969 S2 FHC
#4 Re: ALTERNATOR ANYONE?
Post by mgcjag » Thu Jun 04, 2026 4:13 pm
Hi Steve..easiest way to sort this is to get a diagram for your alternator model....this will show what the connections are..and work from there...or as Geoff mentions a self regulating alternator would be an upgrade..Steve
tim wood
#5 Re: ALTERNATOR ANYONE?
Post by tim wood » Thu Jun 04, 2026 4:17 pm
I’ve heard of single wire alternators, 3 wire alternators but how many wires on this one? I’m having mind madness counting them ?
If it were me I’d strip that lot out and start again. The suggestion of an alternator with a built in regulator is a good start/ idea.
Tim
Stevemorris
#6 Re: ALTERNATOR ANYONE?
Post by Stevemorris » Thu Jun 04, 2026 4:37 pm
No its the wires that I have pulled up from the oil filter area that I'm interested in...
MSM
#7 Re: ALTERNATOR ANYONE?
Post by MSM » Thu Jun 04, 2026 4:58 pm
OK. Understand.
Mike
1969 S2 FHC
Stevemorris
#8 Re: ALTERNATOR ANYONE?
Post by Stevemorris » Thu Jun 04, 2026 5:07 pm
Thanks Geoff!
I did consider changing to a newer style, the 3AW/4TR system is pretty outdated I suppose...
I do like the idea of going back to basics regarding my car and the sign light being actually an OP light though, and I guess with this modern alternator approach I can do that!
I think now I have found some info in the wire positions on the back of my alternator I will attempt to get this one working as it should first, by re wiring the connections and dumping the 3AW canister, Ill let you know mate.
Thanks, Steve.
Stevemorris
#9 Re: ALTERNATOR ANYONE?
Post by Stevemorris » Thu Jun 04, 2026 5:12 pm
Tim
Again thanks for the sound advice Tim.
The alternator set up (according to the wiring diagram) has 4 wires with the 3AW set up, the 4th wire I would suggest literally just grounds the bulb circuit until the alternator spins up?
Ill see if I can tidy things up a bit then if I can get it working correctly ill see how it goes, first sign of alternator failure and I modern one is going on!
Best regards,
Steve.
Stevemorris
#10 Re: ALTERNATOR ANYONE?
Post by Stevemorris » Thu Jun 04, 2026 6:23 pm
So just to confirm chaps, when my car left the factory it DID NOT have a 3AW Canister? The wiring diagram kind of suggests it's either or??
Thanks chaps,
Best regards,
Steve.
Iansparky
#11 Re: ALTERNATOR ANYONE?
Post by Iansparky » Sat Jun 06, 2026 4:02 pm
My Jan 1965 does not have a 3aw, ignition light is powered from the oil pressure sensor
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
Stevemorris
#12 Re: ALTERNATOR ANYONE?
Post by Stevemorris » Sat Jun 06, 2026 4:47 pm
Hi Ian, Thanks for confirming this!
Can I ask a favour? could you take a photo of the back of the alternator and the wires out of the 4TR Regulator please and either PM me them or post here? Mine should be the same as yours and hopefully soon will be!
Thanks again Ian,
Steve.
