THROTTLE LINKAGE BOLTS
Stevemorris
#1 THROTTLE LINKAGE BOLTS
Post by Stevemorris » Wed Jul 08, 2026 3:23 pm
Hi all, I am replacing the throttle linkage bush, in the bracket on the bulkhead under the wiper motor. I am attempting to remove the bolts that hold said bracket to the bulkhead, and it appears there are nuts on the other side. Now from memory, these had captive nuts, can anyone confirm please?
Any other ideas to replace the bush easily? I was thinking to make a diagonal cut in the bush, and feed it in??
Thanks, Steve.
1965 Jaguar ‘E’ Type FHC
Iansparky
#2 Re: THROTTLE LINKAGE BOLTS
Post by Iansparky » Wed Jul 08, 2026 4:35 pm
They are captive nuts on my 1965 series 1,
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
40GT
#3 Re: THROTTLE LINKAGE BOLTS
Post by 40GT » Thu Jul 09, 2026 6:42 am
Try this thread, viewtopic.php?f=4&t=21767 , it also mentions the problems most cars have with varying tickover due to engine twist/movement.
They are captive in the bulkhead yes.
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
Stevemorris
#4 Re: THROTTLE LINKAGE BOLTS
Post by Stevemorris » Tue Jul 21, 2026 10:55 am
I did the best thing and as suggested on here loosened the 4 1/4" wiper motor bolts. This gave me access to both the bracket bolts and it was quite easy from there.
Thanks chaps! Steve.
