I am about to start a LHD/RHD conversion on my 66 FHC (4.2). Might as well install a new loom while I am in a mess. The opportunity arises to improve/simplify (?) the circuits.
I am unable to find a 3AW unit, nor the oil pressure/warning light sender that I expected to find on the right side of the block.
A previous owner changed the original Lucas alternator to a (more modern?) unit with no identification, but apparently a Motorola unit. Even though the present alternator appears to work OK, I am happy to put in a 'modern' one if there is some benefit in terms of simplifying the circuit, and making it more robust. I am not interested in concourse so fewer bits in the system is attractive.
Does a 'single wire' alternator imply that there is no longer a need for the 3AW, 6AR or 4TR units? I intend also to replace the ammeter with a voltmeter, thus removing the need to route the main currrent supply through the dash, but there may be other 'improvements to consider?
single wire alternator
johnhcrighton
Topic author - Posts: 21
johnhcrighton
#2 single wire alternator
I am told that the answer to my wuestion is that if you use a 'modern' alternator (with internal regulator) you no longer need the 3AW, 4TR and 6AR units
John Crighton, Currumbin, Australia
#3 Re: single wire alternator
John,
that is correct. However if you search this site, you will find the information you need. ALternatively, have a look at www.jag-lovers.org where you will be able to access loads of relevant information as a number of people have done this conversion already.
