Asbestos? - plus - Bonnet fitting
skiday
#1 Asbestos? - plus - Bonnet fitting
Post by skiday » Wed Apr 11, 2012 11:57 am
Two unrelated question;
Is the heat shield which fits above the central exhaust baffles made of asbestos? There is a steel layer, then what is, I presume, asbestos. Now that I've changed the gearbox support for my LT77 conversion it clashes with this heat shield which now needs trimming, but if it's asbestos.....
Secondly; do you have tips for bonnet fitting. It is of course very heavy and very delicate I would be very gratefull for tips. As I have new frames there will be much fiddling with the shims before it is right no doubt and I don't have many people to help me.
Andrew
Andrew Day. Former owner of S1A 4.2 2+2. Current cars; Aston Martin DBS 1968, Ferrari F355 & Fiat Coupe 20vt. Flag of choice; EU
Post by Heuer » Wed Apr 11, 2012 12:02 pm
Andrew
Dave Kerr is our resident expert on shields as he makes new one's so maybe he can advise before you start cutting.
There is a bonnet fitting guide in the Forum 'Knowledge Base' under Technical Guide's.
skiday
Post by skiday » Wed Apr 11, 2012 12:35 pm
Thanks - I did look in the knowledge base, but couldn't find it, sorry, but could you give me a link please. Ta
Also, What is Dave?s screen name? I did a search under author but nothing came up.
SteveG
Post by SteveG » Wed Apr 11, 2012 12:41 pm
Andrew,
I was just looking at this in the knowledge base, link below;
http://moutons.org/Jaguar/Photos/Bonnet%20Removal/
Steve - 1966 2+2 1E50101 slow restoration
Post by Heuer » Wed Apr 11, 2012 1:01 pm
Andrew
Send a PM to 'Dave K'
Bonnet fitting instructions: http://dl.dropbox.com/u/8496016/bonnet.pdf
They are in this thread along with door and windscreen fitting guide's; plus a whole lot more! http://etypeuk.com/forum/viewtopic.php?t=1664
jongant
Post by jongant » Wed Apr 11, 2012 5:30 pm
Hi all............my only contribution to this debate is the modified version of the bonnet pins that I turned up. Dimensionally, They are the same as the std, but made out of a piece of 1 1/4 hexagon SS bar. The big head allows for turning to free it off when stuck in position and allows for a set of mole grips to pull on it whilst twisting it.
As an aside, I noticed when copying the std ones I had once bought, that the 5/8 diameter was in fact oversize and was never going to go home without destroying the nylon bearings.
This mod is possibly the best I have ever made.
Its my first time posting a photo so I hope this works.
Jon
Jon Gant
