Dipping, Stripping, Baking and Blasting advice.
#1 Dipping, Stripping, Baking and Blasting advice.
Has anybody had any dealings with either http://www.envirostripukltd.com in Tamworth or http://www.paint-strip.co.uk in Preston?
The first is offering Chemical dipping/stripping then I take back to repair followed by re dip and prime.
The second is Bake, Soda blast then I take home to repair followed by dip, bake and prime.
Any feedback, pros and cons, or advice is hugely appreciated as I am somewhat bewildered.
The general consensus seems to be that chemical stripping of the complete immersion type is very risky in the long term . The stripper finds its way into crevices from which it then leaches out over a long period and ruins the new paint. Similarly, anything done with blast media requires enormously thorough preparation of the shell afterwards to be rid of all traces of the medium . Not very helpful, I know, but forewarned is forearmed
Thanks, as said, it seems a minefield so any input is much appreciated, especially from anyone with first hand experience. Both companies say they have experience of E types but it would be great to hear direct from someone on here that may have used them or the process.
We dipped a S2 2+2 bodyshell. Came back looking great over the next few weeks rust starting appearing where two panels butt together. I wouldn't do it again. If I was to do it again, I'd look into soda blasting. I would be concerned about getting all the paint stripper off if using Nitromors etc.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
There is a company that does ice blasting. I am sure there was a discussion on this somewhere on the Forum.
Edit: Yup - here: http://etypeuk.com/forum/viewtopic.php? ... hlight=ice
If any company is going to grit blast using any sort of media and then dip the car you can almost guarantee they will have got rid of every bit of grit.
My experience when working in a car plant that had an electrophoretic dip was they wouldn't touch anything unless it was absolutely clean.
The tubs are taken through at least 5 high pressure washes from all angles. If any grit or blast media gets into the dipping tank then the whole process is ruined.
I used Nitromors on my paint for the large panels and then had everything else blasted. I then took most of the stuff into work for dipping, great process and you'll never have to worry about rust it the paint gets pulled inside every panel and box section.
Hope thaat helps a bit with your decision.
First hand experience of dipping
Do not do it. Mine went through the whole process inc e-coating.
My car has never got wet since its VERY expensive nut and bolt resto (not Etype) all original metal and a previously Non rusty car
Now I have suspicious bubbles appearing between rolled edges etc.
I have heard from a good source that an owner of a pair of priceless Ferrairis is taking them to task after being dipped.
S1 4.2 Roadster in Resale Red
Thanks again for all the great advice. Obviously a very important stage of the restoration so don't want to get it wrong.
We hire out the K?rcher Ice Blasters http://www.icecleaners.co.uk but don't carry out the work although keep getting asked to!!!
Ice blasting is slow but A LOT cleaner, no media mess and won't stretch or ping any panels.
I'm at home dying slowly but hope to be at work tomorrow if you want to call and have a chat about it: 0345-890 3600 opt1
malk,
You might like to look into "crushed walnut media",I used this on my 356 cabriolet,great finish,best I have used,a bit of hoovering and cleaning out of the seams before primer,would not use anything else. :D
I too had my shell blasted with crushed walnut shells as a media type, very good and am pleased with the finish. The shell was acid etched afterwards and once put back on the spinner and turned over a few times most of the media residue has dispersed.
Would use this method again.
Steve - 1966 2+2 1E50101 slow restoration
Hi All,
I online clean my turbines with crushed walnut shells also. 8)
Kind Regards John
Thanks "Malk" for the contact number reference ice blasting, I will give you a call. And thanks to those who have suggested the walnut method, something else to look into.
