Hi Guys.
I Have recently taken over as custodian of an injected V12 s3.
Took it for a shake down run, (an automotive epiphany, what an awesome car) and noticed that when I apply the brake peddle pushes back on initial application then works normally.
Anyone seen this problem before?
Any ideas on how to rectify this issue would be greatly appreciated.
s3 Brake Pulse
I have come across this particular issue BUT before you get your hopes up
No one as come up with a solution. It is as if the pedal presses back on your foot before the brakes are applied. Anyone with a knowledge of this phenomena??
DC
DC
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
ralphr1780
Fellows,
Seems same issue as described in the running post "brake pedal kick back" in Technical / Ser 1.
I confirm having come across the same, and solved it!
Ralph
'69 OTS + '62 OTS - Belgium
Thanks,
I Checked that out, will get a rebuild kit and pull the servo apart and check it.
Any one know where the above post as gone.ralphr1780 wrote:Fellows,
One of my winter jobs
thanks in advance
ralphr1780
