I have an mot advisory that says "nearside inner rear drive shaft uj which forms part of the suspension he slight play in a universal joint"
The car is a 1966 series 1 2+2
My question is as follows. Is the item a cross shaped item as that is what I have been suplid by SC Parts. Also, there appear to be two of these each side under the car, and I assume its the inner of these two given th advisory says inner?
Finally, is there any video etc regarding replacing one of these ?
Thank you
Help required re mot advisory
Yes, the u/j is cross shaped. Suggest you take the car along to Ken Verity at Series One Spares 01709 838352 as he is local to you (Rotherham) and get it checked over before you start swapping bits.
