Brake master cylinder pushrod
jingleycatjaguar
#1 Brake master cylinder pushrod
Post by jingleycatjaguar » Mon Nov 10, 2014 9:58 pm
Is there anyone out there that could measure their brake master cylinder pushrod please?
Part number C26529.
Its for a series 1 4.2, 2+2. It should be the same on a series 2.
The early ones had a different part number ( C25901).
Mine is 85mm from the clevis pin hole to the end.
The reason I ask is that I have excessive travel on my brake pedal before anything happens. Everything is brand new and properly bled. It has occured to me that if my pushrod is too short that may be the cause of the problem.
38E
Post by 38E » Thu Nov 13, 2014 11:15 pm
I have a spare pedal box here (with the earlier part number) and the pushrod measures 5-1/2" (139mm) from the centre of the pivot to the end.
(Not from my 3.8, it's from a 4.2, about 1964)
Clive, 1962 Coupe 860320
(sold)
jingleycatjaguar
Post by jingleycatjaguar » Fri Nov 14, 2014 9:09 am
Thanks for the reply. It seems that I have the correct one. THe problem with the excessive travel looks like a sticking piston in the NEW master cylinder. Its being rebuilt today so hopefully I can re assemble it tomorrow.
Post by abowie » Sat Nov 15, 2014 12:45 am
If once you have reinstalled it you have the same problem, try pressure bleeding the MC.
Post by PeterCrespin » Sat Nov 15, 2014 10:45 pm
jingleycatjaguar wrote:Thanks for the reply. It seems that I have the correct one. THe problem with the excessive travel looks like a sticking piston in the NEW master cylinder. Its being rebuilt today so hopefully I can re assemble it tomorrow.
Be sure to adjust the threaded pedal stop to prevent the pedal coming up too high.
jingleycatjaguar
Post by jingleycatjaguar » Sat Nov 15, 2014 11:26 pm
That begs another question,. What is the correct adjustment for the pedal?
Post by PeterCrespin » Sun Nov 16, 2014 12:45 am
Whatever you like so long as the piston returns far enough to replenish the circuit from the M/C reservoir.
