winking ignition warning light?
Kes
#1 winking ignition warning light?
Post by Kes » Fri Jan 06, 2012 1:06 pm
Anyone any idea why the ignition warning light within the speedo on my 1969 S2 is flashing on and off when the engine is running - the battery indicator dial reads normal so seems to be charging well and the oil pressure good (I seem to remember that the oil pressure is somehow linked to the ignition light?) It seems to keep winking regardless of engine speed...
Thanks,
Kes
No problem is that great that it can't be run away from.
Regency Red 1969 Series 2 roadster.
Iris Blue 1962 MGB roadster
1954Etype
#2 Re: winking ignition warning light?
Post by 1954Etype » Fri Jan 06, 2012 2:19 pm
Kes, the ignition warning light was only connected to the oil pressure light on the early 4.2s (up to 66ish).
You should have a 3AW canister near the LHS of the bulkhead. Could be this failing. (BTW, if you need a new one, Mike Frank of Coolcat does an electronic replacement - much more reliable).
Mark Gordon
Post by Mark Gordon » Fri Jan 06, 2012 2:21 pm
Have you checked the connection of the wire that leads from the alternator to the warning light? If one or more of the wires that attach to the back of the alternator are loose, crimping the contact for a tighter fit should solve the problem.
Kes
Post by Kes » Fri Jan 06, 2012 3:31 pm
I've just checked the Battery: 12.4V with the engine off and 13.6 with it running at idle, going down to about 13.2 after the lights are switched on. I'll go check the connections to the alternator - any other suggestions if that's ok?
Kes
andy303
Post by andy303 » Fri Jan 06, 2012 5:29 pm
Kes: I will second the Moderator's suggestion. I had the exact same problem last summer. Although the car never let me down I found the blinking lamp to be an annoyance.
Mr. Frank's gizmo did the trick. Check it out: http://tinyurl.com/25sjjjf
Also, it is so small that the original 3AW can be left in place (with the leads removed) and the new device will tuck in behind it.
Andy Blackley
Chardon, Ohio
69 S2 2+2 http://www.xkedata.com/cars/detail/?car=1R41606
Fear God and Dreadnought
Kes
Post by Kes » Fri Jan 13, 2012 12:18 pm
Thanks for all the suggestions chaps - problem now sorted, and I thought I'd just let you know that the problem was....one of Mr Franks gizmos!
We traced the problem to an electronic relay replacement which was faulty. I've now replaced it with an original type 3AW relay from Barratts and all is well. Was very glad of the link posted to the Coolcats website though - the wiring diagram there made swapping the units over easy.
thanks again for the info.
K
1954Etype
Post by 1954Etype » Fri Jan 13, 2012 12:58 pm
Excellent! Thanks for the follow up post.
rossbraithwaite
Post by rossbraithwaite » Mon May 20, 2013 7:58 am
I also have an intermittent winking ignition warning light. I am sure that I replaced the 3AW unit a few years ago and the car has been used very little since then. I have just replaced the terminals on the wires to the 3AW and the alternator.
Are there any tests that can prove the state of the 3AW?
Is it possible that the alternator (diodes?) could be responsible?
Thanks,
Ross
Kes
Post by Kes » Fri May 24, 2013 5:13 pm
The 3AW relays are notoriously dodgy - for what they cost I'd try replacing that that first, even though the one in your car is only a few years old.
rossbraithwaite
Post by rossbraithwaite » Mon Jul 01, 2013 9:38 am
I have just replaced the 3AW again with a brand new item from SNG and guess what? No Change. Does anyone know; what else can cause these symptoms? and how to bench test the 3AW? I assume that 2 12v power supplies with lamps in series connected to the appropriate terminals?
rossbraithwaite
Post by rossbraithwaite » Thu Aug 28, 2014 9:36 am
Hi all,
The ignition warning light is now on permanently and the ammeter shows strong positive charge for most if not all the time. The car starts and runs fine but is there a chance of frying the battery? is this likely to be an alternator or relay problem?
Thanks,
Ross
Post by Heuer » Thu Aug 28, 2014 11:52 am
A 4TR voltage control unit fault most probably. Have you tested or replaced it?
rossbraithwaite
Post by rossbraithwaite » Thu Aug 28, 2014 12:20 pm
Hi David,
Thanks. No I have not but will do so now. I just wanted an opinion of where to start- with the 4TR or the alternator itself.
Thanks,
Ross
Mark Gordon
Post by Mark Gordon » Thu Aug 28, 2014 2:22 pm
You might want to test the alternator, regulator (4TR) and warning switch (3AW). The procedures are easy to do and are well explained in the shop manual. I recently got stranded about 50 miles from home with a dead battery. (The car died while driving because I lost enough voltage to run the fuel pump). Luckily, I was able to get the battery charged and drove home on the battery alone. I guessed that my alternator had failed. It turned out that the alternator, 4TR and 3AW were all bad and needed replacement.
SE5
#15 Winking ignition warning light
Post by SE5 » Thu Aug 28, 2014 6:14 pm
Hi Ross,
I had the same problem with the warning light on my '68 Ser.1.5 and I tried all the usual remedies but nothing worked. I finally checked the alternator relay and found a broken wire inside. I replaced the relay and the problem was solved.
Stuart.
Stuart 68 E-Type FHC
Moeregaard
Post by Moeregaard » Thu Aug 28, 2014 7:35 pm
Back in the late 1980s, I replaced the 4TR regulator as a matter of course when I rebuilt the alternator. After a series of intermittent charging problems, I finally connected a multimeter and gave the alternator and regulator a series of light taps. This soon revealed a problem within the regulator, and I found a loose solder joint inside. Once repaired, it gave no more trouble. The regulator was an aftermarket copy of the 4TR made by Huco.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
rossbraithwaite
Post by rossbraithwaite » Mon Jan 05, 2015 5:15 pm
I finally got this sorted over the Christmas break. It turned out to be the 3AW which I had assumed to be OK having only recently bought it from SNGB. I have also swapped the alternator so hope the light will stay out now. I did try to follow the procedure for fault finding but due to a combination of a lack of expereince and lack of equipment I was unable to pinpoint the 3AW as the faulty part.
Thanks for all your help.
Ross
JaggyWag
#18 Regulator Fault?
Post by JaggyWag » Wed Jan 28, 2015 9:14 am
Hi folks, does anyone know about the reliability (or otherwise) of the replacement regulator boxes? These appear to be sealed for life so no access to the internals.
Mine seems to be charging more than a bent lawyer...just had the alternator rebuilt and bought a new regulator from David Manners. Battery has reasonable charge but gauge and separate meter test both show over 17 volts at 4000 rpm? Turning the adjuster on the regulator has no effect, red dashboard light on constantly (which I think it would be for under or over charging?)
About to return the regulator for a replacement, but anyone offer any words of wisdom before I do, please?
Many thanks
Peter (Series 3 2+2)
Minerva
Post by Minerva » Wed Jan 28, 2015 10:02 am
I have had these problems for years and never managed to sort it but the car runs fine. I too changed the 3AW and it made no difference. The car will run for 20 mins before the light starts to show and then finally on all the time.
The other symptom is the ammeter needle can bounce erratically when in the lower revs. (S1.5 4.2).
Post by mgcjag » Wed Jan 28, 2015 10:07 am
Hi Minerve have a look at the condition of the brushes in the alternator.......Steve
