Post
by PeterCrespin » Sat Apr 18, 2015 1:35 pm
With a bit of luck an engineer who knows what they are talking about will answer, but if nobody else says anything you'll have to put up with me. I just expanded the pic (still on iPhone) and it looks fractionally worse than I thought.
If that were a nick on a conrod I wouldn't use it. If it were a pit on a crank cheek you wouldn't hesitate. Since it's where it is, there's probably room for debate.
On a four cylinder three bearing crank I'd be wary, same as on a four main six. It is on a high-stress area but the XK is pretty much overbuilt and hails from a time long before they pared everything down to a minimum based on computer analysis etc. If it was the centre main on a 4.2 I might be a tiny bit worried but it's not. You're right that cranks can fail at the transition from journal to cheek but that's if they flex and the transition is sharp. Neither applies to that part in your intended usage IMHO. The torque harmonics are a bit of a crap shoot but a small surface imperfection might be insignificant in terms of crack propagation/breakage.
Bottom line is you're still talking about a road engine and you have polished and balanced the crank so I'd use it, fitted with a good fluid damper (which should damp all frequencies).
What's the worst that can happen? You have to find a new crank and conceivably a block and a valve tangle if the timing drifts. I don't think you're risking a total grenade explosion and the chances are very high nothing at all will go wrong.
Since it is off the bearing area and the total anount of metal removed wiuld be small, I think you could dress it smoother with the right tools and not affect total section or balance meaningfully. However there's more than one pit so you might end up chasing your tail a bit. There's no rubbing, so filling is not needed. Probably best to leave it after you've done what you can to take any edges down.
