This is why you fit a 5 speed box.
Post by malcolm » Tue Dec 15, 2015 8:18 am
I can tell you that my 4.2 with 3.07 and standard diff does exactly 70mph at 2850 RPM
skiday
#22
Post by skiday » Tue Dec 15, 2015 11:09 pm
alfred wrote:nice to see someone else using the kiss principle to correct their spedo. Mine has a yellow dot for 100 km and a red one for 120.
Alfred
I had mine calibrated by 'Speedy Cables' in Wales, which is pretty essential if you're changing the gearbox I would have thought. It is now bang-on.
I must check out how my car compares for revs at the same speed, although it's not often I get to 5th gear in the Isle of Wight!
Which reminds me - isn't '5th Gear - now on ITV4, just total cr*p! If Channel 5 didn't want it any more it should really tell Mr Needell and Ms Henderson-Butler something!
Andrew Day. Former owner of S1A 4.2 2+2. Current cars; Aston Martin DBS 1968, Ferrari F355 & Fiat Coupe 20vt. Flag of choice; EU
dal2.0litrefrogeye
Post by dal2.0litrefrogeye » Wed Dec 16, 2015 8:41 am
Electronic speedo for me , after fitting one to my sprite I couldn't go back to a wavy needle one :idea:
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
5speeds
Post by 5speeds » Sat Dec 19, 2015 12:22 am
The JT5 uses the exact tooth count speedo gears the factory 4 speed has. So if your speedo is off it is not the gearbox. Angle drives also have certain ratios, make sure you are always using an agle drive for the 6 cylinder E-type. Many people have installed JT5 units without dropping the rear. Sliding the driveshaft through the tunnel and dropping the yoke in the transmission from the top is the way most people do it. You can also grind the case is you need more clearance.
Thanks,
andrewh
Post by andrewh » Sat Dec 19, 2015 5:52 pm
malcolm wrote:I can tell you that my 4.2 with 3.07 and standard diff does exactly 70mph at 2850 RPM
thats 4.2s for you. My 3.8 does 74mph with a 3.07 diff at 2850rpm :D
1962 3.8 Series One FHC
Post by Heuer » Sat Dec 19, 2015 6:37 pm
RPM to MPH Calculator (check your gear ratios): http://wahiduddin.net/calc/calc_speed_rpm.htm
Post by mgcjag » Sat Dec 19, 2015 7:40 pm
Think your missing out on that grin factor if you like those lower revs ... .been told this happens as you get older....have a box and o/d sitting in the garage to put on but just dont want to lose that E type driving experiance even down the motorway.....PS now the fuel is cheaper make the most of it.... :lol:
andrewh
Post by andrewh » Sat Dec 19, 2015 7:48 pm
The issue reminds me of driving my RS2000 when I was younger. King of the road. Yes topped out at 115mph flat out in forth but you really felt that you were driving. I don't mind a few revs to be frank. Cruising on both UK and European roads now is max 90 mph average so I reckon on balance standard revs and gearing is ok
iani
Post by iani » Sat Dec 19, 2015 8:26 pm
mgcjag wrote:Think your missing out on that grin factor if you like those lower revs ... .been told this happens as you get older....have a box and o/d sitting in the garage to put on but just dont want to lose that E type driving experiance even down the motorway.....PS now the fuel is cheaper make the most of it.... :lol:
That's why I bought an S type OD Box Steve, the non OD ratios are exactly as per the standard S2 4sp, I can have all the high revs I need whenever I want, then flick the OD on to relax.
Ian
E-type - TBC
1968 Triumph GT6 Mk1
Post by mgcjag » Sat Dec 19, 2015 8:51 pm
Hi Ian.....must have a chat before Xmas...will call you....was only stirring it up really...im sitting in my comfy chair with my slippers on :D ....just cant face pulling the engine to fit the box.....feel like doing a bit of charity work for me..... :lol: ....
iani
Post by iani » Sat Dec 19, 2015 8:54 pm
mgcjag wrote:Hi Ian.....must have a chat before Xmas...will call you....was only stirring it up really...im sitting in my comfy chair with my slippers on :D ....just cant face pulling the engine to fit the box.....feel like doing a bit of charity work for me..... :lol: ....
I'd love to have the time chum but you should remember life as a wage slave! Give me a call one evening, I'm in the office until Thursday unfortunately.
Ian
E-type - TBC
Post by malcolm » Sun Dec 20, 2015 11:30 am
That's interesting Andrew; I thought the 3.8 was slightly lower geared than the 4.2, and of course has a slightly higher red line start at 5500 rather than 5000. I thought that the higher revs allowed for the lower gearing. Is all this not the case, or is your car running on higher gearing than normal?
Post by abowie » Sun Dec 20, 2015 9:06 pm
4th is 1:1 in all the boxes.
My 4.2 has a 3.07 diff. My 3.8 has a 3.54.
Redline is related to the engine not the gearing.
AussieEtype
Post by AussieEtype » Sun Dec 20, 2015 11:53 pm
Andrew - any recommendations for sourcing a 5 or even 6 speed kit for a V12 in Australia?? Oh that is cost effective?
15 years ago I put a 5 speed Getrag off a 5 litre Commodore on the back of my engine but is really a home made job that sort of worked OK but now I am thinking of getting something more professional in the car.
Garry
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
