brake calipers with 2,88 differential from XJ-S
carlv12
Spain
#1 brake calipers with 2,88 differential from XJ-S
Post by carlv12 » Thu Mar 24, 2016 7:55 pm
Hello,
there are different stories about upgrading an E-Type V12 with a 2,88 differential from XJ-S:
1) must I use the XJ-S brake calipers instead of the E-Type ones?
2) must I use the XJ-S hand brake brake calipers instead of the E-Type ones?
I hope here on this Forum there are a few experts that already have done this conversi?n and know bout this question.
Thank you in advance and best regards from Valencia (Spain)
Carlos
Zei220
Post by Zei220 » Thu Mar 24, 2016 9:21 pm
I changed the diff on my s2 from the 3.54 to the xjs 2.88 and reused the original brake calipers and handbrake, without problems.
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
D COUPE
#3 2.88 DIFF
Post by D COUPE » Sat Mar 26, 2016 2:16 pm
I did the 2.88 diff swap and used all my original brakes .....
DC
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
