Poor Petrol Pipe to Fuel Filter Body Connection
JC
#1 Poor Petrol Pipe to Fuel Filter Body Connection
Post by JC » Thu Apr 07, 2016 6:50 pm
On my SII, I'm replacing a section of the petrol pipe that goes the length of the car from the fuel tank into the fuel filter.
It's the flared connection into the fuel filter body that giving me grief. Ive flared some pipe, but it when I tighten up the end pipe bolt fully it clearly doesn't press home the flared connection enough and so the pipe is still slightly loose.
The filter body looks fine and so I suspect that either, I've created an incorrect flare or I'm using the wrong sized pipe.
Does anyone have any of the following
  • A link to an actual picture of the correct flare - I searched www in vain
    A specification of the pipe that I should be using
    An alternative explanation
Cheers, JC
BRM
#2 Re: Poor Petrol Pipe to Fuel Filter Body Connection
Post by BRM » Thu Apr 07, 2016 7:49 pm
JC wrote: An alternative explanation
JC, the pipe should not be flared, it should be plain with an olive on the end.
Brian
1969 S2 FHC 1R20267
1960 Austin Healey 3000
wol916
Post by wol916 » Fri Apr 08, 2016 1:21 am
Purchase the olive from your local plumbing/gas supplier and not the usual suspects to save yourself the normal 500% mark up because it?s ?for an e-type?.
Warren
S1 FHC 4.2 OSB
chrisvine
Post by chrisvine » Fri Apr 08, 2016 1:55 am
Before you make up the pipe including the correct olive, you might also want to check the brass fitting that screws into the filter housing.
I had problems obtaining a seal on the olive due to an incorrect brass compression fitting. The one I was supplied had a shoulder section which wasn't threaded which resulted in only a small amount of thread being engaged before it bottomed out on the olive. It makes it easier to cross thread and also possibly cause a fuel leak as there's insufficient clamping force.
The correct fitting (top) is threaded to the end:
Chris
1969 S2 OTS, Elise S1
Alty Ian
Post by Alty Ian » Fri Apr 08, 2016 10:55 am
Chris
Yes I had exactly the same problem, I couldnt find the right one so machined the shoulder off mine and it was fine then.
Ian
64 S1 4.2 OTS 1E10012 73 S3 2+2 manual 2013 V6 F type OTS
JC
#6 Many Thanks
Post by JC » Mon Apr 11, 2016 10:07 pm
Thanks Chaps, olive purchased and correctly fitted. I did have the correct 'hollow bolt' fitting!! Cheers, JC
