Speedomoter woes
ssplant
#1 Speedomoter woes
Post by ssplant » Thu Apr 14, 2016 9:20 pm
Is it possible that the magnetic wheel loses its magnetism? In the case of my speedo the drag cup moves freely and moves the needle and the input shaft will turn the magnet. But the magnetic wheel will not turn, does not turn/effect the drag cup!!
Simon. S. Plant.
Post by christopher storey » Fri Apr 15, 2016 9:00 am
Simon : the magnet rotating within the cup can lose its magnetism although it is not very usual in my experience ( exposure to the strong field of a demagnetiser is the only thing which occurs to me as a likely cause ). Try lifting the needle over the stop and seeing where it comes to rest - it should lie on a small white spot which is just the "wrong" side of the stop, and it could be that the needle has got twisted on the cup shaft , which might create your problem , because of course the spiral spring tension would then be wrong . If that does no good, Speedograph Richfield in Nottingham are highly recommendable .
Post by mgcjag » Fri Apr 15, 2016 9:09 am
Hi Simon....good news that you now have an E.....what did you get.....didnt see that you posted it anywhere......was it the one that you couldnt get up north to view.....all the best Steve
#4 Re: Speedomoter woes
Post by abowie » Fri Apr 15, 2016 10:15 am
ssplant wrote:Is it possible that the magnetic wheel loses its magnetism?
Yes which is why they don't work accurately Or it's the spring. They are 50 years old after all.
The easiest thing to do is use a GPS to check your speed and put markings on the dial.
Post by Gfhug » Fri Apr 15, 2016 10:22 am
You could always send it here for an overhaul, not expensive, and there are others who will do the job.
http://www.speedograph-richfield.com/
Edited to add: Apologies Christopher, didn't read your post fully otherwise would not have repeated your advice. Will stand in corner for a while :oops:
