Hi All ...
trying to do some cost effective repairs on my V12 for once ! i.e myself doing it !
headlight issue ...if anyone can suggest what to try next or even perhaps some wire colour codings to check !
so issue ....
I have side lights but no head lights from the central dashboard switches and cannot turn on full beam either
i can though flash full beam from the steering column stalk/control....
does anyone have any thoughts that could save me ?
I have so far tracked the power through the fuse box ( all goo ) and out to the rear of the main sidelight and main lights switches - current is also flowing out of the switches ....... so i am guessing / assuming / hoping that the issue is somewhere from their to the front bonnet ... i have not checked both bulbs each side for main as thought probability of both dip filaments and not both full beam was less than anything else ......
is there a relay perhaps between the dash switches and the front headlights that could have blown/broken? wouldn't that affect all lights though not just the dip beam issue i am having ?!?
any help on checks i can do or idea gladly received as i have hit a bit of a brick wall on my diagnosis !!
thanks in advance
" home-help electrician"
P.S its originally a US car if that makes any difference for diagnosis ?
1972 S3 headlight issue
#2 Re: 1972 S3 headlight issue
No relays involved but two fuses which you say you have checked (both?). First thing to do is disconnect the big plug connecting the loom to the bonnet and using a test meter or lamp to check you are getting voltage on the various pins - specifically 2 and 3 for high and low beam respectively:
#3 Re: 1972 S3 headlight issue
I thought i had checked all - but will check again for sure
thankyou
thankyou
#4 Re: 1972 S3 headlight issue
thankyou for the notes re which pins on the bonnet connector as wasnt sure ...
