Will A XJ6 S1 inlet manifold fit?
fandeland
#1 Will A XJ6 S1 inlet manifold fit?
Post by fandeland » Sat Sep 19, 2015 1:57 pm
I'm in the process of replacing the US spec series 2 intake (with Strombergs)?to twin SU's from a XJ6 S1
I'd like to get rid off the original primary and secondary intake manifolds and fit the XJ single manifold. The SU tops are now about 2cm higher than the Stromberg. I'm not yet near fitting the bonnet back onto the car so the question is : will the carbs hit the bonnet once closed?
Alban
Alban
E-type S2 2+2, 3 Weber’s, O/D gearbox
Range Rover Classic 1987
Post by PeterCrespin » Sat Sep 19, 2015 5:47 pm
Probably. Note that depending which style of manifold you have there may be problems hooking up the bypass hose and the air bleed. The carb XJ pmanifolds normally have a small built-in header tank too.
fandeland
#3 Re: Will A XJ6 S1 inlet manifold fit?
Post by fandeland » Wed Aug 24, 2016 5:36 am
I finally managed to get the bonnet back on the car. I can now confirm that the front carb does foul the bonnet when closed. :banghead: just some clearance is missing, probably 7-8mm only
I'll refit the original US spec inlet manifold and modify it to bypass the secondary plenum.
Alban
#4 Re: Will A XJ6 S1 inlet manifold fit?
Post by malcolm » Wed Aug 24, 2016 8:30 am
Just wondered why you're replacing the Strombergs with twin SUs? I knmow the US spec twin strombergs aren't as efficient as the UK triple SUs, but didn't think that 2 SUs would be better than 2 strombergs? Or is there another reason?
fandeland
#5 Re: Will A XJ6 S1 inlet manifold fit?
Post by fandeland » Fri Aug 26, 2016 4:55 am
I primarily wanted a cleaner look and get rid off the complicated US spec inlet manifold. I'm told that the SU have better airflow caracteristics so I'm hoping to get good drivability. Must say that with the couple of runs I have done so far, I'm not disappointed. Finally I have better tuning knowledge of SU's.
Alban
David Oslo
Norway
#6 Re: Will A XJ6 S1 inlet manifold fit?
Post by David Oslo » Fri Aug 26, 2016 12:48 pm
What are you doing for the air filter box? Are you continuing with the Stromberg US-style box, or swapping over to the S1 triangular funnel and cylinder, or maybe just K&N's
David
S2 OTS '70 (arriving)
