How to remove C20179 oils seal retainer from outer IRS fulcrum
vrracing
#1 How to remove C20179 oils seal retainer from outer IRS fulcrum
Post by vrracing » Sun Dec 04, 2016 5:11 pm
I'm replacing the felt with a modern seal but it is not obvious to me how to remove the C20179 oils seal retainer; a small metal cup pressed into the hub.
Thanks!
Jim
70 E-type OTS
Mich7920
#2 Re: How to remove C20179 oils seal retainer from outer IRS fulcrum
Post by Mich7920 » Sun Dec 04, 2016 5:58 pm
Hi Jim,
Here is the order of the parts
To fit out the C20179 you can use a hook on a extractor with inertia or make a lever with a crew driver.
In all cases, you work slowly by the inside of the C20179 at several opposite points of this ring.
Mich
Michel
vrracing
#3 Re: How to remove C20179 oils seal retainer from outer IRS fulcrum
Post by vrracing » Sun Dec 04, 2016 8:30 pm
Thanks, Mich. Just what I needed.
70 E-type OTS
