HT Leads
#1 HT Leads
HI, I'm look for a diagram of the HT lead layout. Were they are on the distributor( the position of number one lead and were they go to the engine block.
Trev
Trev
Hi Trev....that very much depends on tbe position of your distributor but the fireing order is 1,5,3,6,2,4 so No1 piston nearest to windscreen get it to top of its compression stroke and look at where the position the rotor arm is pointing at, thats 1......then continue Anti clockwise around dizzy 5,3,6,2,4
ANTICLOCKWISE
AND 153624 not 153642....!
Too Young, Too Old & Just Right....allegedlyPeterCrespin wrote:AND 153624 not 153642....!
E-type - TBC
1968 Triumph GT6 Mk1
Must be the first signs of dementia.....just goes to show you should get the manual out and look it up yourself and dont believe everything thats written on a forum......just going for a lay down in a dark room
have edited my mistakes and now correct
#8 HT Leads
Thank you all for your help!
You save me getting old trying to work it out.
Regards Trev
Regards Trev
Trev, you should seriously consider buying a manual. This is all basic stuff.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#10 Re: Ignition timing setup
I have the Jaguar Service manual (Series 1 E type) and could not find reference to the firing order in the whole manual?1954Etype wrote:Trev, you should seriously consider buying a manual. This is all basic stuff.
Where or what page is it please?
Also Is there on this very informative forum a picture to show ignition setup, like 6 pots in a row numbered 1 - 6 (left to right) and the distributor shown in correct orientation with terminals numbered in firing order ??
For me, This would tell me instantly how it should be. (I could draw this and upload it for the forum once its confirmed correct) or I would be surprised if it does'nt exist somewhere ??
I know its basic stuff, but only ever driven (and worked on!) a v12 never a 6.
Thanks for any information provided.
Keith
#11 Re: HT Leads
As Steve said, if you turn the crank by hand so that No. 1 Cylinder is at the top of it's compression ratio, the rotor arm on the dizzy will point to No. 1. Then you number them in an anti clockwise manner, 153624. This way you can be certain that it is correct for your engine.
I remember there is a diagram in the Haynes manual showing what you ask, but don't have mine with me at the moment.
-Mark
#12 Re: HT Leads
Hi Keith..look at page B.8 you cannot put numbers on your diagram of the dizzy....you have to look at where the rotor is pointing......this then fires the cylinder thats on its compression stroke
#13 Re: HT Leads
Prepared to be shot down here, but at (10 degrees before) TDC on the firing stroke, doesn't the rotor arm point to number 6 front cylinder not number 1 at the back?
#14 Re: HT Leads
Yes and no. It depends which of these two is on its compression stroke. One will be 360 degrees of crank rotation from the other. Or 180 degrees of dizzie rotation.paulsco wrote:Prepared to be shot down here, but at (10 degrees before) TDC on the firing stroke, doesn't the rotor arm point to number 6 front cylinder not number 1 at the back?
#15 Re: HT Leads
Yes agreed, but the service manual instructions for setting the ignition timing states that the engine should be set to (10) before tdc on the firing stroke of the front cylinder (6), ie the rotor arm is pointing to 6 and 6 is firing not 1
#16 Re: HT Leads
Hi Paul...yes you are correct.....the original poster asked where no1 lead went on the distributor so the answer was with no cylinder on the comp stroke.it goes to where the rotor is pointing.........i think the confusion comes from some wanting a defined position on the distributor eg 2 o/clock.....but this can be a bit vague.....also that the crank goes around twice....so if you say set to 10deg befor tdc on one revolution it will be 1 on its comp stroke and the next revolution it will be 6
#17 Re: HT Leads
Thanks Steve, right there at the bottom of the page! putting on 2 pairs of glasses did the job!mgcjag wrote:Hi Keith..look at page B.8 you cannot put numbers on your diagram of the dizzy....you have to look at where the rotor is pointing......this then fires the cylinder thats on its compression stroke
Keith
#18 Re: HT Leads
Thanks Guys, and with Pauls' comment here, I have numbered the dizzy and believe I have it correct to setup and drop in your dizzy in the right orientation.. Please confirm it is correct (or not!).paulsco wrote:Yes agreed, but the service manual instructions for setting the ignition timing states that the engine should be set to (10) before tdc on the firing stroke of the front cylinder (6), ie the rotor arm is pointing to 6 and 6 is firing not 1
#19 Re: HT Leads
Hi Skippy....yes that look correct so long as your no 6 piston is up on its compression stroke
#20 Re: HT Leads
-Mark
