Oversize Valve Shims
vern jones
#1 Oversize Valve Shims
Post by vern jones » Sun Jul 09, 2017 9:06 pm
Hi I am just setting my valve clearances and I could do with some oversized valve shims around the 150" though I see standard they only go to 110". Do you know who would sell them or are they used in other vehicles in the sizes I require.
Any help greatly welcomed.
Many Thanks
E600
#2 Re: Oversize Valve Shims
Post by E600 » Sun Jul 09, 2017 9:12 pm
I would like to know why the need, unless its a reprofiled cam surely something is amiss. Check VSE as they do cam reprofiling and I have had oversize shims from them in the past.
vern jones
#3 Re: Oversize Valve Shims
Post by vern jones » Sun Jul 09, 2017 9:22 pm
Hi yes it does have high lift cams fitted while in the states. Thanks for your help
#4 Re: Oversize Valve Shims
Post by mgcjag » Sun Jul 09, 2017 9:26 pm
Hi Vern.....you should be able to get then from SNG...possibly to order.....you could also try CMC they have a parts dept...or terrys jag in the US has them all listed https://www.terrysjag.com/category/E-TY ... SHIMS.html whats the problem..have the top of the valves been ground down? All the best.. Steve
vern jones
#5 Re: Oversize Valve Shims
Post by vern jones » Sun Jul 09, 2017 9:34 pm
Hi Steve hows things. Its the high lift cams I guess, I shall try SNG and that VSM. Cross my fingers
Dawnpatrol
#6 Re: Oversize Valve Shims
Post by Dawnpatrol » Tue Jul 25, 2017 10:20 pm
The racy profile will have been reground onto std cams then re treated. This results in a smaller base circle diameter for the cam hence the need for bigger shims.
This is a much cheaper option than the others. Rob Beere will have what you need!
Also means the tappet bucket is slightly less engaged in the guide, which if they are worn will increase top end noise.
If the valve tops have been ground in the past you could partly restore the situation with new valves.
What are to gapping them to btw?
Michael
1961 OTS LWE, 1965 OTS, 1966 FHC.
