1969 Series 2 USA OTS
Im working my way round the things that do not work and Ive come to the cooling fans which do not work.
I have applied power to the separately and they both work fine.
I have put a meter on each of the 2 wires both sides and it seems the left hand wire on both is the earth and there is no power.
So my question is Where is the power coming from ?
what colour do we think it is ?
and what else would i be supplying? so I can try and trace back where the fault has started ,
Also does the switch in the top of the radiator earth them or supply power ?.thank you
Also can anyone tell me what this is in the photo below? as you can see its position on a cross member just behind the cooling fans so could it be to do with them ?
once again I thank anyone for taking the time to read this and share their knowledge .
Grant.
