Well the results of all this shenanigans are in.
I brimmed the tank and I arrived at Emerald in Norfolk at 9am, who strapped the car down, ran it on the rollers remapped the new configuration and these are the results.
Then I brimmed it again when I got home.
"Before" is with a standard 1967 4.2 head and "after" is with a mid eighties Jaguar XJ6 Injection "big valve" head and cams. Nothing else has been changed apart from the ignition map for the new head of course.
Before, Max bhp 198.5 bhp 146 kw @ 4,775 rpm, 220 ft lb 300 nm @1,000 rpm, 250ftlb 340 nm @3,425 rpm
After, Max bhp 229.2 bhp 171 kw @ 4,800 rpm, 225 ft lb 305 nm @1,000 rpm, 275ftlb 372 nm @3,775 rpm
192 miles used 36.1l (7.9 gallons) 24.5 mpg including full power runs.
85 mph is achieved at 3,276 rpm. So 70 would be 2,697 rpm. that is 25.9 mph/1,000 rpm with the 2.88:1 axle.
So BHP is up 15.5% at 30.7 hp 22.8 kw and torque is up 10% through the range an increase of 24.5ftlb, 33 nm.
The car certainly feels nice, smooth and quicker
The engine has 8:1 pistons and 3,600 miles on it, running 175 psi an all cylinders..
