Thanks Bill, I knew I must have done it for some reason other.angelw wrote: ↑Sat Aug 29, 2020 9:12 amJames Wrote:Hello James,After I did it, I did wonder why I had bothered, as there is not much wrong with having the stalk on the other side anyway!
Well, yes there is. If you don't move the Indicator Stalk to the outside, by rotate the Steering Lock/Ignition House to it's mirror image position, when converting the column from LHD to RHD, the outside profile of the plastic enclosure will foul with what should be the corresponding shape of the lower edge of the Dash Panel.
Left/right indicator conversion help
#21 Re: Left/right indicator conversion help
