Brake pedal sticking down
#21 Re: Brake pedal sticking down
Post by MarekH » Sun Jul 31, 2022 9:33 pm
You might also find that part #25 above (the plate bit at bottom left as referred to by Steve in his post) has sharp edges and so binds (when hot). It wants to be free to fall over backwards when the little piston pushes it back on release of the brakes. Smearing red grease into the end there would do no harm.
#22 Re: Brake pedal sticking down
Post by abowie » Sun Jul 31, 2022 9:35 pm
ianc9 wrote:
Sun Jul 31, 2022 8:20 pm
Stripped the master cylinder out
So options are to purchase a new assembly or rebuild this one - but I need a circlip.
You've done well. Getting the plastic retainer ring out can be very difficult.
It's worth trying to rebuild this one but you need to be absolutely sure you work out what's binding. You can't buy the plastic components, only the rubbers, so a new unit still has some attraction.
The circlip will be generic; it's only there to hold the retainer ring in.
If you get desperate I have a couple of these in my shed; I can make measurements etc.
gtjoey
#23 Re: Brake pedal sticking down
Post by gtjoey » Mon Aug 01, 2022 2:52 am
WELCOME TO JAGUAR ETYPE REPRODUCTION PARTS!
Its a shame, I would throw that away.....
Find a nos on line or an old core and rebuild that.
Its a shame that the products are such junk.
I went through 3 for a good one, SO FAR.....
GTJOEY1314
#24 Re: Brake pedal sticking down
Post by chrisfell » Mon Aug 01, 2022 7:48 am
"Started dissembling it and found a number of issues:"
Welcome to the joys of PO discovery. I'm still finding things done by POs on my car almost twenty years into my guardianship.
#25 Re: Brake pedal sticking down
Post by abowie » Mon Aug 01, 2022 9:56 am
Its a shame,
I see this sentiment repeated ad nauseum on Jaguar forums, and frankly it wears thin after enough repetitions.
I think that it's worth considering that we are very fortunate that the vast majority of parts for our niche 60 year old cars are available at all, in any form.
We've all had the experience of the odd part that wasn't up to scratch but 99% of them are good, and keep our cars going with minimal effort on our part.
After a while, complaining about it reflects more on the purchaser than the supplier.
I'm involved with a group who maintain and restore veteran cars from the early 1900s. We spend days making parts for the cars that if they were E types could be bought off the shelf. If we can get one to copy. Or a drawing. Or a photo.
This week I'm rebuilding an IRS on one of my cars. I've been able to order EVERY part in one go from a single retailer. They'll be here next week. How good's that.
Sometimes, I think you need to be cognisant of your blessings.
So to the poor OP whose thread has been hijacked, personally I'd just buy a new master cylinder confident in the overwhelming likelihood that it will work just fine.
Mich7920
#26 Re: Brake pedal sticking down
Post by Mich7920 » Mon Aug 01, 2022 12:15 pm
:yeahthat:
Michel
#27 Re: Brake pedal sticking down
Post by christopher storey » Mon Aug 01, 2022 3:44 pm
Ian :
Assuming that your master cylinder is genuinely from an S1.5 , and has not been substituted with something else the brake cylinder master repair kit , including the piston assembly complete , AND a circlip, is part number C26767RK available from Barratts France for Euro 64.28
https://www.sngbarratt.com/English/#/FR ... ING(18226)
I hope this helps ( and cheers you up!)
PS I have also sent you a private message about this
#28 Re: Brake pedal sticking down
Post by abowie » Tue Aug 02, 2022 11:01 am
Good to see that they're now supplying these.
I'm going to order a couple as I have a number of otherwise perfect MCs.
ianc9
Ireland
#29 Re: Brake pedal sticking down
Post by ianc9 » Wed Aug 10, 2022 8:44 am
I disassembled the master cylinder, reassembled in correct order and all sticking has gone. I also bled the system using the catheter syringe method and have a pretty good pedal now. Not perfect, but I'm ok with it.
Thanks for all the help here.
I think I'm also going to buy one of those kits Just in case.
Next question will land in this section shortly :)
Ian.
1968 E Type S1.5 2+2
1953 MG TD
1974 Mercedes 450SEL
1983 BMW R70 Cafe racer
Tesla Model 3 LR - to make up for all the fuel used above!
#30 Re: Brake pedal sticking down
Post by abowie » Wed Aug 10, 2022 10:18 am
Good outcome!
gtjoey
#31 Re: Brake pedal sticking down
Post by gtjoey » Sun Dec 11, 2022 9:05 pm
Is there a theme guys?
Gtjoey1314
