They are constant vacuum carbs (or CD/constant depression) and therefore adjust air/fuel supply according to load. Within reason, they will deliver the correct fuelling on any suitable engine that can generate sufficient air flow over the bridge. At the absolute limit you might need to do some tweaking, or if you alter things from stock, but for all Jag's road cars the triple SUs were on the side of 3.8 or 4.2 engines - the 3.8 breathing faster at its higher rev limit and the 4.2 breathing deeper albeit at a lower red line. Hence things evening out overall and the same basic carb setup being used throughout.andrewh wrote:I would have thought that there would have been a need for bigger jetting to cope with the increased cubic capacity, are the jets different then if the needles are the same?
