Mangoletsi wire throttle upgrade
Hugo
#21 Re: Mangoletsi wire throttle upgrade
Post by Hugo » Wed Oct 02, 2019 3:20 pm
I would pop the pedal box out & see what's going on in there - seems an odd place to stick. Or unhook the cables first to make sure? ;)
Simonpfhc
#22 Re: Mangoletsi wire throttle upgrade
Post by Simonpfhc » Thu Oct 03, 2019 6:22 am
Hi Alex,
My setup had similar symptoms as you, but maybe not as severe. Anyway, my fix was to re-align the small clamps that connect to the return springs for each carb (the ones that drop down below each carb). I loosened each one and rotated them slightly so that they apply the most force when the throttles are closed. Mine had previously been clamped so that they apply ‘some’ return force across the whole range of movement, so that by the time the throttles were closed, the spring tension wasn’t that strong.
Good luck!
62 3.8 FHC
91 Porsche 928GT
Hugo
#23 Re: Mangoletsi wire throttle upgrade
Post by Hugo » Thu Oct 03, 2019 9:03 am
Sounds as though something is wron somewhere. It shouldn't need any effort to close the throttles. I spent some time fiddling with mine to get it right, and the action is a sheer delight. When I had assembled it, I would stand there operating the throttles by hand because it felt so nice ;)
