4.2 Typical oil consumption
Post by Heuer » Thu Aug 20, 2009 9:26 am
Thierry
This is the JEC sender:
Similar shape to yours but only one spade connector. As far as I can see yours is not a JEC sender. The gauge should be marked JEC on the back I seem to remember (I sold mine after fitting a mechanical one).
Original, JEC and mechanical gauges
Echezeaux
#22
Post by Echezeaux » Thu Aug 20, 2009 10:49 am
Again, thank you David and I will check the back of the gauge.
Thierry
3.8 RULES
I want to die peacefully in my sleep, like my grandfather,not screaming and terrified like his passengers.
on2wheels
Post by on2wheels » Mon Dec 07, 2009 5:10 pm
Hi Oilers,
When changing oil and filter does one need to follow the owners manual and drain the oil from the filter first? (Another connection to undo and re-seal)
Then unscrew the cental bolt and remove canister element.
Nick
Post by christopher storey » Mon Dec 07, 2009 6:37 pm
Well, it is certainly less messy to do it that way, although if you drain the sump first the majority of the oil in the filter will drain down as well. I always get at the filter by removing the air filter drum - you get less oil in your eye that way! because it is easier to manouevre the filter bowl . Whatever way you do it , however, there tends to be some spillage, so have some rags handy before you start
daverawle
Post by daverawle » Mon Dec 07, 2009 8:31 pm
christopher storey wrote:I always get at the filter by removing the air filter drum - you get less oil in your eye that way! because it is easier to manouevre the filter bowl . Whatever way you do it , however, there tends to be some spillage, so have some rags handy before you start
That's one of the best mods I made - dispensing with that almost inaccessible nut on the base of the air cleaner and replacing it with a captive nut plate.
1963 OTS
