Durango2k wrote:I did make a wooden bed for the head, and used it, so I can say no valve was bent.
Carsten
I can say some valves ARE bent - maybe not on the bench but afterwards. This assumes they were correctly fitted initially, with good springs, ruling out sticking once they were opened.
Your block has been rebored with new Mahle pistons, which run tight clearances. Even with a broken ring or two on #1 & 6 you would have significant compression. The only way you can have zero compression is a bent valve in my opinion. If the cam timing was crazy then that would bend valves, as would just turning the crank or one cam and not the other before everything was hooked up.
Your engine has not run, so a major gasket blow is effectively impossible, unless you messed up fitting so badly it would probably pour coolant out as well as not holding air. I doubt that is the situation, especially at opposite ends of the block.So if you rule out valves already being bent before the head was fitted and you rule out a massive gasket problem, the only thing left is incorrect assembly technique, which is only possible by not following the book.
You would certainly not be the first one to be caught out by a DOHC hemi engine after working on pushrod or SOHC engines.
If you put # 1&6 at tdc firing stroke in turn and pressurise each one via a hose connected to an old plug body (or your compression test adapter?), you will hear where the air is comIng out - amost certainly the intake side. Strip, repair and reassemble following the book and you will have no more trouble. If you cut corners or do not follow the book - especially about valve set up in the head or head reassembly to the block, it may happen again. Those are the two most common ways to bend a valve apart from with the head on the bench, which you say did not happen. At least the engine does not have to come out of the car, although you will need new gaskets.
