Page 1 of 5
#1 Quick Release Steering Wheel
Posted: Sun Jan 08, 2017 9:34 pm
by caveman
I'm looking into investing in a quick release steering wheel boss to adapt onto my original wheel and also wish to do the conversion myself. I believe that there are now three options/manufacturers open to us (see below) but little in the way of comparison within the forum from what I have seen, any information/advice would be much appreciated.
Superspoke £268.00
SNG Barratt £495.00
CMC-Classic Motor Cars £495.00
#2 Re: Quick Release Steering Wheel
Posted: Sun Jan 08, 2017 11:05 pm
Hi Steve...have a read through this link......it covers some of the options...also details an option tbat i fitted
viewtopic.php?f=2&t=8886&hilit=Quick+release+steering
#3 Re: Quick Release Steering Wheel
Posted: Sun Jan 08, 2017 11:16 pm
by 288gto
Hi Steve,
From what I've seen the SNG one and the one from CMC are the same, so that narrows it down to two.
There was a recent topic on here about the Superspoke one.
My observations, and this is only my personal take on the two are as follows.
CMC / SNG. Closer to the original look of the existing boss and in my opinion more in keeping with the car.
Superspoke. Better engineered but for me not as nice when viewed from the side.
I have no affiliation with either and am like you still at the research stage.
Probably no help at all.
However there are a few threads on here if you look and a fee videos on YouTube.
Edit. I've just noticed Steve has replied while I was typing, his link is worth a look.
#4 Re: Quick Release Steering Wheel
Posted: Mon Jan 09, 2017 3:24 pm
by caveman
Steve/Simon,
Many thanks, you've both covered exactly what I was hoping for and having seen videos etc I am more inclined towards the aesthetics/operation more than cost, although now that there is only two options, (I did think SNGB & CMC design looked similar...... thanx Simon), the big price difference is something worth considering.
I had already exhausted the forum for information but I couldnt find anything outwith how they fit/remove and the posts are some time old now and technology does move fast so initial niggles, (horn push connectors etc), should have been sorted now or thats what I'm thinking.
Initially, I read that Superspoke wanted you to send your original wheel to them for conversion........is this still the case?
Thanks again.
#5 Re: Quick Release Steering Wheel
Posted: Mon Jan 09, 2017 4:33 pm
Hi Steve....I did speak to Superspoke at the Stonleigh show....he did say they were looking to have units made that will directly fit a S1/2 wheel without re drilling it...give them a call......one thing to note is that with the Superspoke unit it does bring the steering wheel about 40mm closer to the driver.....check this measurement with them...if you do go with them make sure you fit the spacer collar (ask for details) without it it is possible for the wheel to disconnect if you push on the steering wheel..........the only quick release that when viewed from the side looks the same as the original set up is the CMC/SNG....Both the Superspoke and NRG that i fitted when view from the side you can see the aluminium release unit......hope this helps
#6 Re: Quick Release Steering Wheel
Posted: Mon Jan 09, 2017 4:45 pm
by Heuer
I have the CMC version and it looks stock and works faultlessly. No modification to the horn push or arrangement. If you are in doubt contact Angus Moss - he only fits the CMC version, which says it all really!
#7 Re: Quick Release Steering Wheel
Posted: Mon Jan 09, 2017 8:43 pm
by caveman
Thanks for all your replies.
A bit worrying if the Superspoke has a slight fitment issue and, as you mention, the boss seems a little large and not really what I am looking for.
The CMC unit sounds very promising, I take it the earlier problem of changing the steering shaft at the same time is no longer the case and the boss will fit direct to original shaft & wheel with no modification.
#8 Re: Quick Release Steering Wheel
Posted: Mon Jan 09, 2017 11:08 pm
As far as i know you still have to change the shaft......you will probably also have to go on there waiting list
#9 Re: Quick Release Steering Wheel
Posted: Tue Jan 10, 2017 10:55 am
by Heuer
You do indeed need to change the shaft as it has fewer splines, a key spline and machining to allow the locking mechanism to locate. Easy enough to do.
#10 Re: Quick Release Steering Wheel
Posted: Tue Jan 10, 2017 11:58 am
by caveman
That'll explain the extra cost but at least its a simple enough job to do though.
#11 Re: Quick Release Steering Wheel
Posted: Fri Mar 17, 2017 2:55 pm
by helge.kassel
Hi Steve in the first letter You said, You want to make the conversion Yourself.
In my SeriesII FHC i've made this conversion two weeks ago.
I ordered from funkypower.co.uk an NRG adapter, the thin one.
It took small amount of fiddling to adapt it to the different style horn push, but it works fine.
Later i saw this NRG-adapter at Ebay for a lower price again.
I think, for Your seriesII it will work fine.
Regards from Seville
Helge
#12 Re: Quick Release Steering Wheel
Posted: Sun May 07, 2017 7:48 pm
by caveman
Hi Helge,
Thank you, that's interesting and something I will look into.
#13 Re: Quick Release Steering Wheel
Posted: Wed Apr 24, 2019 12:15 pm
by rfs1957
Could anyone update us on any changes in this sphere since these last posts ?
Keen to make this modification but didn't want to miss out on any evolutions that might influence my choice.
Still CMC ?
#14 Re: Quick Release Steering Wheel
Posted: Fri May 17, 2019 9:17 pm
by caveman
I didn't fit one in the end as I couldn't justify the cost at the time. I may well look into them again at some stage in the future.
#15 Re: Quick Release Steering Wheel
Posted: Sat May 18, 2019 12:45 am
by JJC
Hello all my fellow E-Type lovers.....once again, I have a question that I hope someone can answer. Never too old to learn. The question is simply.....why ?? Why would you go to the trouble and expense of adding a quick release to a street car ?? In my early days, I professionally drove Formula Atlantic (F2) in North America for years, and then drove in the IMSA /Rolex endurance championship up till just a few years ago. They were, thank God, equipped with quick release steering wheels. In endurance racing, they were great simply because the teams always had several drivers of assorted sizes. Much quicker pit stops. But please help me understand why you would put one in a street car ?? Thanks !
JC
#16 Re: Quick Release Steering Wheel
Posted: Sat May 18, 2019 6:28 am
by 1954Etype
Security
#17 Re: Quick Release Steering Wheel
Posted: Sat May 18, 2019 7:23 am
And for some...to ease getting in and out
#18 Re: Quick Release Steering Wheel
Posted: Sat May 18, 2019 9:55 am
by Heuer
It certainly makes working on the interior of the car much easier. Cleaning, modifying, maintaining and security. Once you have one you will wonder how you managed without it.
#19 Re: Quick Release Steering Wheel
Posted: Sat May 18, 2019 10:02 am
by PeterCrespin
JJC wrote: ↑Sat May 18, 2019 12:45 am
Because they are prettier than a 9 mm Glock.
#20 Re: Quick Release Steering Wheel
Posted: Sat May 18, 2019 8:34 pm
by johnetype
Now, where's my "Protected by Smith and Wesson" bumper sticker gone
